Maxwell Render
It is currently Fri May 24, 2013 4:03 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: displacement material?
PostPosted: Mon Nov 14, 2011 4:47 pm
Why I can't to apply the pretesselated displacement material on the rhino object ( I checked the pretesselated), I only using the "on the fly"?
and I can't move the displacement layer to the second level layer, it is only on the first level layer, why?
Top
 Profile
PostPosted: Mon Nov 14, 2011 9:33 pm
How do you know it is using on the fly? The only differences when using pretesselated should be higher memory usage, faster rendering, and slightly different response to displacement input parameters (mainly, the Subdivision parameter).
In the plugin, the displacement node is always at the top level, under the material's node. In MXED, you can add multiple displacement components, but you can only render one of them -- which one to render is chosen using a drop-down in the main material page in MXED.
_________________
Next Limit Team
Top
 Profile
PostPosted: Tue Nov 15, 2011 5:20 am
How can I send the file to you for see? thank you!
Top
 Profile
PostPosted: Tue Nov 15, 2011 5:38 am
If you want to send me a file, you can send it to jeremy at nextlimit dot com. But I am not sure if you need to do that, since I do not yet understand the nature of your issue.
_________________
Next Limit Team
Top
 Profile
Search for:
Jump to:
