Maxwell Render
It is currently Sun May 26, 2013 2:13 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
Author Message
PostPosted: Sat Nov 05, 2011 7:02 pm
This thread holds known bugs, and their workarounds.
_________________
Next Limit Team
Top
 Profile
PostPosted: Wed Jun 20, 2012 12:26 am
2.7.0: an error occurs when attempting to clear a grass map. (fixed in 2.7.10)
_________________
Next Limit Team
Top
 Profile
PostPosted: Mon Jul 02, 2012 6:24 pm
2.7.0: using displacement causes Maxwell Fire to crash. (fixed in 2.7.10)
_________________
Next Limit Team
Top
 Profile
PostPosted: Tue Jul 17, 2012 4:23 pm
All versions: given two instances of the same component, where both are axis-aligned, and where the component definition contains axis-aligned faces, faces can randomly disappear from the rendering.
Info
This is a rarely-seen engine bug, which is being worked on. It has already been fixed once in internal betas, but the fix had bad side effects, and had to be rolled back.
Workarounds
There are three known workarounds:
    1. Apply a slight rotation to affected component instances.
    2. Explode and group one of the components, or use Make Unique, in order to prevent the geometry from being instanced.
    3. Disable instances entirely (available in the RS plugin only; see Scene Manager > Output > Export > Instances).
_________________
Next Limit Team
Top
 Profile
Search for:
Jump to:
