Maxwell Render
It is currently Fri May 24, 2013 6:44 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Thu Jun 14, 2007 2:42 pm
Is it possible to resume a merged coop mxi file so that you can continue on all your computers?
ie.: I setup a coop job that went out to 4 machines - time was set for 9 hours. After it finished it merged the 4 nodes to a single mxi. Now I want to resume, but I need all four computers to resume (resuming that single merged mxi on one computer would be too slow).
So how is this accomplished?
Thanks!
Top
 Profile
 Post subject:
PostPosted: Thu Jun 14, 2007 3:22 pm
Hello, any MXI can be resumed.
Except when doing "File->load image" or "File>Save MXI". Those MXI will only have image information. But any MXI generated by a render can be resumed no matter it is a cooperative, animation, frame...
What you cannot do now is to use cooperative networking to resume a render (several machines resuming an mxi). But you can resume the result of a cooperative render with a single machine.
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Thu Jun 14, 2007 4:10 pm
Thanks, that's too bad.
Top
 Profile
 Post subject:
PostPosted: Fri Jun 15, 2007 12:35 am
Hi: what is the procedure for resuming a mxi file from mxcl?
_________________
Best regards
Top
 Profile
 Post subject:
PostPosted: Fri Jun 15, 2007 6:07 pm
goto the file menu and select 'resume mxi', then select the mxi file you want to resume and point maxwell to the mxs that was used originally.
Top
 Profile
 Post subject:
PostPosted: Tue Jun 26, 2007 12:51 am
one can always resume the mxi separately with different seed and then merge them manually... cant one?.. maybe not
_________________
win xp 32- e6600 - lw plugin
vista 64 - i7 2,67 ghz - 8gb ram
Top
 Profile
Search for:
Jump to:
