Maxwell Render
It is currently Fri May 24, 2013 4:31 pm
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: attaching geometry
PostPosted: Mon Jun 11, 2007 10:30 am
What is the best/fastest way to attach geometry inside max? attaching a large number of objects is a painful and slow task...
When I export files to maxwell, i end up with hundreds of layers/objects and it is a pain to select all objects that share a material and merge them. Usually i never need to move objects inside studio, but it would be nice to be able to have max groups translated to maxwell groups, ... is this possible?
Top
 Profile
 Post subject:
PostPosted: Mon Jun 11, 2007 11:31 am
Hello,
you have attach by list in any edit poly or mesh modifier. You can select a list of object to attach. If they have the same material you also can select by material and apply collapse option in a single mesh from utilities panel.
Luis Miguel
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Mon Jun 11, 2007 12:01 pm
:shock:
COLLAPSE!!
excellent, never seen that in my life!
Ataching takes forever when there are many objects in the scene, usually running out of ram and crashing my scene.. collapse seems to be faster, true? does it reach the SAME result as the attach command?
Top
 Profile
 Post subject:
PostPosted: Mon Jun 11, 2007 12:03 pm
thank you very much by the way.
Top
 Profile
 Post subject:
PostPosted: Mon Jun 11, 2007 1:56 pm
yes, it is the same but more directly. You don´t need apply a modifier like edit poly to attach your objects, it simply make an internal process and convert all mesh attached in an editable mesh object.
Luis Miguel
_________________
Next Limit Team
Top
 Profile
 Post subject:
PostPosted: Mon Jun 11, 2007 2:28 pm
ok!
thanx Luis.
Top
 Profile
Search for:
Jump to:
